MC2100LS-30 REV
gaslem
Joined May 3, 2023
MC2100LS-30 REV
All is working good except the incline motor...incline motor works to lower but not to rise the treadmill in the up position
help appreciated.
Red light is steady on on board
pic of the board I have
Gaston
MaxHeadRoom
Joined Jul 18, 2013
30,887
The LED is not affected normally by the lift circuit.
Check the two triac's that are clamped together and the two triac driver opto's, right below the motor connections.
gaslem
Joined May 3, 2023
thanks....will check
to be more accurate :
I put the treadmill in calibrating incline
in calibrating , normaly incline go up and after go down
incline motor only go down..did not go up
but after all stopped..i noticed when I push incline up..the incline number is rising from 1 to 10 on the screen, but motor not turning,,, and 10 to 1 when I push incline down
motor turn only to incline down.
what I must check or try ?
excuse my english
Gaston
