MC-60 Treadmill Mouse Poop
Pikeben08
Joined Oct 11, 2019
Bought a used treadmill. When I got it home I found the belt was no longer working. I also found a bunch of mouse poop inside the controller area with some on the board...nice.
I used a brushed and vacuum to get it off as best I could.
The SCR led does not light up, but the speed control one does.
I think I traced the issue to the R21 resistor. I have no continuity across the resistor and with the treadmill set at 6, I get 7V on one side and nothing on the other.
I can try to just replace that resistor, but I worry that it will just pop again.
Any advice on how I can try to check the board out further? Also what should I clean it with?
MaxHeadRoom
Joined Jul 18, 2013
30,775
That reverse engineered one also had a note that it should be 100k but a 80k was actually in that particular one.
So go with 100k.
I sold the MC-60, just have the MC2100 right now.
Max.
