nickelflipper
- Joined Jun 2, 2010
- 280
I don't see where the dsPIC30F3010 actually has an inbuilt analog compare module. So while it has a fault pin input for the PWM module, the implication is that an external signal would still be required?
Looking at say the PIC18f46k22, the internal analog comparator can be used for the PWM auto shutdown source. The comparator response specs are in the 200-300ns range (table 27-1).
As far as putting some sort of kit together, a good sized double column breadboard, and a 350 pc. 22 guage jumper kit would be a good start.
