t_n_k,My inferiority complex is coming back to haunt me.
If you are inferior, what chance do the rest of us have?
That engineers, of all kinds, are inherently lazy stems from our base motive in becoming engineers -- we want to make lots of things the primary purpose of which is to make our lives "easier"! By the time we discover that designing those "things" requires far more work that the work they could ever save us, personally, it is too late; we are hooked. But at least we can sell those things to others to make their lives easier.Then WBahn tells me most electrical engineers are lazy and sloppy - more inferiority.
Oh sure. Just as in electrical engineering one could always begin with KVL and KCL and the constituitive relations for the devices and hammer away. But we develop lots of special case approaches that apply to special case situations that arise on a regular basis. We like to use simple models and then go out of our way, when possible, to design things so that the simple models are reasonable approximations.I note the OP's problem is a special case of a more general problem as one might observe in the attachment [see one of my earlier posts] - case 6 is a special case of case 7. This addresses studiot's comment in part, about needing another more general formula to cover single point loading at some arbitrary location along the beam.
It seems to me one could therefore use this more general relationship to determine the location and value of maximum deflection. It would also include the special case of the loading being exactly at the beam center.
Thanks - will you be my "shrink"?t_n_k,
If you are inferior, what chance do the rest of us have?![]()
So we can have a beam that has a deflection of +1cm at one point and -1cm at another point but both deflections are positive?It is just wrong to talk of negative deflection. All deflection is positive and the minimum deflection is always zero. This value must occur somewhere unless the supports are not rigid.
A deflection may be upwards or downwards and we use signs to indicate this, but cannot be 'negative'.
Yes indeed you can.So we can have a beam that has a deflection of +1cm at one point and -1cm at another point but both deflections are positive?
If I stretch a rubber band, it gets narrower. This is a positve deflection?Yes indeed you can.
The deflection is always positive but the direction varies.
In case you think I am splitting hairs consider this:
A negative deflection would be if you took a rubber band and stretched it and the band got shorter.
I do not know of any occurrence of this in Nature.
The simplest example I can think of from electrical engineering is the negative Hall coefficient of Be, Mg, In, and Al.
To continue the rubber band example.Since that strain can be in either direction, how can it be reasonably said that both strains are positive.
Aha - now I know why the brickwork above the lintel in one of my doorways is cracking!Yes, t_n_k, you can have more complicated formulae in tables.
But the ones you posted would not do even for calculating a lintel over a doorway in real engineering.
This statement made absolutely no sense to me and struck me as a red herring until I was laying in bed last night.A negative deflection would be if you took a rubber band and stretched it and the band got shorter.
Yes it indeed would. But this does not mean it does not make sense. What it means is that a negative acceleration/deflection/whatever is imaginary.This is basically the same as saying that acceleration must always be positive because, if it weren't, it would be if you pushed on an stationary object to the left and it started moving to the right. Or, for a more applicable example to yours, if you pulled on a spring and it got shorter or compressed a spring and it got longer.
| Thread starter | Similar threads | Forum | Replies | Date |
Toy car circuit problem | General Electronics Chat | 17 | |
| J | [SOLVED] Arduino R4 Minima and MAX242 Level Shifter | Microcontrollers | 33 | |
| Z | How to find minima and maxima of polynomial upon polynomial | Homework Help | 3 | |
Calculus-Maxima and Mininma | Homework Help | 14 | |
Calculus (minima) problem | General Science, Physics & Math | 23 |
