MAX7219 and many Leds
FroceMaster
Joined Jan 28, 2012
708
Will gave this setup, but i dont know if the MAX can handle it like this.
I need up to 6 LED in Series and there for i need 12v.
If i put a Transistor in, can i then handle it that way ?
If i can, do i still need the resistor(R1+R2) to Base of transistor ?
Know i need a lot of components more, but for easy i only do this.
ElectricSpidey
Joined Dec 2, 2017
3,359
Only if the LEDs require less than 2 volts to light. (for 6)
Yes, you will still need the resistors...the ones on the base, and the series resistor for the LEDs.
And you should connect the emitters to ground, not an output pin.
ElectricSpidey
Joined Dec 2, 2017
3,359
You only need one transistor for each LED string, assuming the pin can provide the proper base current.
But driving the emitters from a pin defeats the purpose.
FroceMaster
Joined Jan 28, 2012
708
I need all the Segment A-G and then 4 digits, so i will have 28 strings of LEDS . +one or 2 DP.
If i connect E to ground i cant select another digit.
ElectricSpidey
Joined Dec 2, 2017
3,359
I see, perhaps I am making the wrong assumption here, I was assuming you needed the transistor to provide more current.
Sorry.
As long as the digit outputs can handle the current, I see no need for another transistor,
FroceMaster
Joined Jan 28, 2012
708
Ok,, as i can read the datasheet, 320 mA but not sure, but if the MAX can handle ordinary LED Display, and i only use 14-16 mA pr string then i think it will be ok
Tonyr1084
Joined Sep 24, 2015
9,744
I think I missed something. "Control each digit"? Are you asking to be able to light only one LED at a time? Help me - I'm lost (again).
FroceMaster
Joined Jan 28, 2012
708
Or will it be better to make it this way, ?
Giving me 3*16mA = 48mA per segment, 48*8 = 400 mA ( if i write "8" and DOT ) , should have 500 max ?
As i can read from datasheet this should be possible ??
FroceMaster
Joined Jan 28, 2012
708
As i understand the data, i can have 100mA on each segment, and 500,mA on DIGITS
When connected like this, i use 48mA on each Segment, and yes(8*48) 400 mA on the DIG.
And the resistors can i also get rid off. only use 1 central on input of MAX ?
But again, maybee iam wrong,
ElectricSpidey
Joined Dec 2, 2017
3,359
Current isn't the only consideration, you also have to consider wattage.
And no, I don't think you can replace the resistors with a single one on the MAX input.
FroceMaster
Joined Jan 28, 2012
708
Ahh calc the wattage, 24 pr LED and 17 pr R, = 195 mW pr Segment.
7- 8 segment , little to much, ok then i will have to go with 12v and Transistors.
But still i dont know if i can control the E from transistor by the DIGIT output from MAX or du i need a different approch ?
ElectricSpidey
Joined Dec 2, 2017
3,359
Ok so looking at the datasheet, if you drive the LEDs directly you control the current with a single resistor, but the problem is you will have parallel and series configuration, not just series and as many on this board will tell you...LEDs in parallel is a no no.
I personally disagree, but what the hell do I know.
