May I know the output to the DUT pin is an analog or digital signal?It looks like a buffer to me.
may I know the DAC output is an analog signal to the end of the buffer is analog signal or digital signal?The max19001 is not in production. It is old and has been replaced.
The symbol is an amplifier or buffer. There are many inputs that control its function.
If this was an audio amplifier (it is not) the lines at the top would be called Base, Mid, Treble, Loudness, Volume, Mute.
RonS.
I have read the datasheet any the statement state that All digital signals are analog.All digital signals are analog.
Have you read the MAX19001 datasheet?
