max19001 IC
ronsimpson
Joined Oct 7, 2019
4,695
The max19001 is not in production. It is old and has been replaced.
The symbol is an amplifier or buffer. There are many inputs that control its function.
If this was an audio amplifier (it is not) the lines at the top would be called Base, Mid, Treble, Loudness, Volume, Mute.
RonS.
Alex1700
Joined Jan 12, 2020
107
RonS.
may I know the DAC output is an analog signal to the end of the buffer is analog signal or digital signal?
ronsimpson
Joined Oct 7, 2019
4,695
This IC drives a long wire. COAX At high frequencies "long wire" might be short in cm or inches. The output is analog driving digital. At the far end of the wire we want a square wave. The wire adds distortion. So the amplifier adds distortion to compensate. It even compensates for cable loss by adjusting gain. It takes linear to make this distortion.
I have not used this part and don't understand all, but it looks like the goal is to make "digital" by using analog.
