MAX 6373 Supervisor IC's
Bhutan Steve
Joined Jan 5, 2019
I have designed a controller for solar hot water systems.
It uses a Wemos D1 mini (Arduino).
I want to install a simple external watchdog timer.
I purchased the Max6373 for a test.
I can't get the chips to work. It's very simple.. I've designed these circuits from scratch before but I thought the one cup solution would be easier and quicker.
I have a good regular watchdog input signal (1 sec) . I've set the the timeout to ten minutes (and tried other options) but it never send a reset pulse to the uP..??
I even soldered up another one.. But same result..
Any ideas..??
