Max 232 Rs232 interface
Discussion in 'Embedded Systems and Microcontrollers' started by alperolmz, Nov 28, 2016.
  1. alperolmz
    Nov 17, 2016
    Hi Everyone !
    I have an IR LED, phototransistor, max 232 and RS232. Actually, i try to make the connections of these. First of all, I know that I should use an ADC before max232.(I am right ?). I need to use ADC for phototransistor. But, I consider that for IR LED, should I use DAC after RS232's output ?
    As a result, can anybody help to establish the exact circuit ? :/
    Predicted circuit schematic is attached. Let' s make it work :)
  2. MaxHeadRoom
    Jul 18, 2013
    18,211
    5,592
    RS232 word has a particular format, how do you intend transmitting a photo transistor source this way?
    Max.
  3. MrChips
    Oct 2, 2009
    18,696
    5,939
    Why do you want to use MAX232?
    What are you sending the data to?
