matlab increment addition
Gerald27
Joined Apr 10, 2012
6
A= [5 6 7 8]
B= [4 5 6 7]
for i=1:4,
C(i) = A(i+1) - A(i)
D(i) = C(i)*B(i)
E(i) = D(i+1) + D(i)
end
can anybody help me with this code
every time i get a value for D i want to add them to the previous value of D but i am getting an error
Attempted to access D(2); index out of bounds because numel(D)=1.
35,089
You have two problems.
Firstly, why not create D with initial values of 0?
D = [ 0 0 0 0 ]
Secondly, A(i+1) and D(i+1) will both cause an error when i = 4.
Gerald27
Joined Apr 10, 2012
6
D = [ 0 0 0 0 ]
A= [5 6 7 8]
B= [4 5 6 7]
for i=1:4,
D(i) = C(i)*B(i)
E(i) = sum(D(i))
end
i initialize d with zero but thats not my problem
the value of E should equal the sum of the increment of D but it keep giving me the the value of D but not adding them
D = [ 0 0 0 0 ]
35,089
I have no idea what you are talking about.
What do you mean by "the increment of D"?
And after you answer that, what do you mean by "the sum of the increment of D"?
Also remember that MATLAB's strength is in matrix arithmetic. You may not need a for-loop.
Gerald27
Joined Apr 10, 2012
6
D = [ 0 0 0 0 ]
A= [5 6 7 8]
B= [4 5 6 7]
for i=1:4,
D(i) = C(i)*B(i)
E(i) = sum(D(i))
end
thats the results i should get at the end
C=[1 1 1]
D=[4 5 6]
E=[11 15]
for example i have this value D=[1 2 3 4 5 6 7 8 9]
i want to get E=[1+2=3 3+3=6 6+4=10 10+5=15 15+6=21 21+7=28 28+8=32]
so E=[3 6 10 15 21 28 32] thats what i was trying to say
35,089
A = [ 5 6 7 8]
C = diff(A)
B = [ 4 5 6 ]
D = B.*C
Your example
C=[1 1 1]
D=[4 5 6]
E=[11 15]
is not consistent with the second example.
Should it be E = [9 15] ?
Gerald27
Joined Apr 10, 2012
6
yes it should be E = [9 15], typing error, but when i do E= sum(D(i)) i get E=[4 5 6] it return the same value i receive for D
A = [ 5 6 7 8]
C = diff(A)
B = [ 4 5 6 ]
D = B.*C
Your example
C=[1 1 1]
D=[4 5 6]
E=[11 15]
35,089
You're welcome. Don't be afraid to use the Help menu.
In this case searching for diff and sum would lead you to the proper functions.
