Matlab: Deleting pixels from an image (desperate)
Fadel Megahed
Joined Jun 22, 2007
12
I am working on this big project and i would like if anyone could help me generate a code that would delete all pixels under 20 from an image.
I am really stuck in the project and I am desperate for your help
Thanks a lot everyone,
22,114
I'm not clear about your requirements. Do you want to remove the pixels from the image, or do you want to change the value of the pixels to some other value? The first would probably destroy the image. The second, depending on the meaning of less than 20, would produce something that looks like a false color image. It would also help to know what format the image is in. We are not blessed with clairvoyance or astral projection; you're just going to have to tell us, there is no other way.
Fadel Megahed
Joined Jun 22, 2007
12
The image is a .jpg one
The function of the program is to remove the background out of the picture so that when a histogram is developed, it has the focus zones only
Thanks
22,114
OK. Assuming you know the format of a .jpeg file a program might look like the following:
Rich (BB code):
Open filename.jpeg for input
Open Modified_filename.jpeg for output
Read and process header
Copy header to output
while(.not. EndofFile)
    pixel = getNextPixel() ;
    if(pixel < 20) pixel = 0 ;
    writePixel(pixel) ;
Close(filename.jpeg) ;
Close(Modifed_filename.jpeg) ;
22,114
That's terrific, and you didn't even need a tutorial on the pseudo-code language I made up on the spur of the moment. I'm quitting my day job and going into language design. I may have a bright future. On second thought since retirement is just around the corner I think I'll find a couch and take a nap. Yeah...a nap, that's the ticket!
