Matlab Beginner Needs Help!
ruairdh
Joined Nov 13, 2013
1
Hi, I'm new to this site and am trying to teach myself matlab. I came across this problem and can't seem to figure it out;
Write a MATLAB script to derive and plot y(n) below;
x(n) =[1 1 2 1 3] y(n)=x(n)+y(n-1)
I have written the following code;
N = 5;
x = [1 2 2 1 4];
n = 0:length(y)-1;
y(n)=x(n)+y(n-1);
stem(n,y)
...but MATLAB is giving me the following error message;
Subscript indices must either be real positive integers or logicals.
Error in test (line 4)
y(n)=x(n)+y(n-1);
Any help would be greatly appreciated.
Ruairdh
33,109
It's been a couple years since I've touched MatLab, so I'm not even going to try to get the syntax correct. So focus on the idea.
You have
N = 5;
x = [1 2 2 1 4];
This means that
x[1:5] is [1 2 2 1 4] (remember, I'm not trying to use MatLab syntax)
Now, what if we concatenate this with a matrix that has just a single element. Let's assume that I have a function called 'zeroes' that takes two arguments, the number of rows and columns, and returns a matrix that size filled with zeros. Let's further assume that we can contatentate two matrics by using a cat() function.
So
x_n_minus_1 = cat(zeroes(1,1), x) would yield [0 1 2 2 1 4];
while
x_n = cat(x, zeroes(1,1)) would yield [1 2 2 1 4 0];
Now I have
y = x_n + x_n_minus_1
which will have a length of N+1
I can put this all on one line
x_n = cat(x, zeroes(1,1)) + cat(zeroes(1,1), x);
I know you can do each of these things in MatLab and that, in doing so, you get somethign that generally runs much faster than using a loop. This is called "vectorizing" the problem and anytime you can vectorize a problem and eliminate a loop, the dividend is usually pretty impressive.
