That curve isn't for saturation mode. Vce will be low when the transistor is saturated.Given the attached datasheet
If you go by currents, it's when further increases in base current don't result in corresponding increases in collector current.how do i know that my PNP is sutrated from the currents in the bjt?
Could you make a voltage source interpretaion of the circuit?
Transistor controls by B-E voltage.Transistors respond to current not voltage.
by Aaron Carman
by Jake Hertz
by Aaron Carman
