Input matching of class C amplifier
froten
Joined Dec 22, 2023
I have constructed the circuit shown in the figure which is class C amplifier for 27MHz transmitter, and is working as expected.
I have no problem matching the amplifier output to the load, the help I need is to match the amplifier input to the signal source (the signal source has 50 Ohm output impedance), I just need a way to get an approximate value of class C amplifier input impedance, or a simple method to measure it, or even a rule of thump is adequate, to design the input matching network.
Thanks in advance for any help
froten
Joined Dec 22, 2023
Hi froten,
This is one method of measuring Zin and Zout of the C class amp Vin & Vout.
E
Thanks eric for your reply. I'm aware of this method but I think it is not applicable for non linear circuits, if you check collector current in AC analysis you find it far from real value, I found it about 0.4 ma in LTspice simulation under .ac analysis.
28,567
This looks like a power amplifier intended for CB radio use, and for an AM signal a class C amplifier will not be suitable to provide a useful output, other than jamming a frequency band. Because of the drive requirements, a class C amplifier is not useful for an AM signal.
