Hello! I want to wire some LEDs and I'm not sure how to do it.
I want to wire as many 12V 10W LED Pads I can from a Philips LED Power Driver 60W 24V 2.5A. What is the best way to do it?
The solution I found is 2 series of 3x parallel LED but I'm not sure is a good solution.
Full specifications of a LED:
Specification(10w)
Model Type: High Power Integrated Chip lamp Beads
Chip size: 24MIL*44MIL
Integrated approach:3 Series 3 Paralleling
Forward Voltage:9-12V(if use DC 12,Recommended Series a about 1.50 ohm resistor to use)
Forward current: 900mA
Luminous Flux: 90-110LM/W
Color-rendering index: 60-85
Beam Angle: 170 degrees
Working Temperature: -20 centigrade to 60 centigrade
Color Temperature: Warm White: 3000-3200K
White: 6000-6500K
Lamp Body Material : Pure Copper Bracket
Life Span: 120,000 Hours
Specification(10w)
White: 6000-6500K
