Making output voltage same as input voltage for CD4060B counter.
WBahn
Joined Mar 31, 2012
33,084
Yes 3 red LED's. I need to find a way to increase the current externally if thats the case. I dont want to get off topic here, this might be another thread, but I need at least 3mA or 4mA of current on the output frequencies. Basically the LED's are just indicators of the frequencies, then I have the output frequencies going past the LED's with wires. I am not aware yet if 4060B outputs square waves which is what I want from all the outputs at 99% duty cycle and positive offset with no negative spikes.
Since it's a counter, the outputs of each stage will be 50% duty cycle.
It would sure help if you posted a schematic.
WBahn
Joined Mar 31, 2012
33,084
I'm not convinced this guy knows what the hell he is talking about. The 4060 is NOT regulating the voltage. He is abusing the 4060 and relying on its lack of drive capability (essentially high output impedance) to keep it from destroying itself or the LEDs -- very, very poor design practice. He mentions about how removing some of the LEDs impacts the behavior of the rest of them -- well, that's a hallmark of abusing a chip and making it not behave according to spec . He also refers to it as a multiplier chip. It's not. It's a ripple counter.
WBahn
Joined Mar 31, 2012
33,084
I assume this will be placed before the LED?
Does a MOSFET work for this?
Yes. It inverts the polarity of the signal, but that may not matter if you are just making a light flasher.
But you still have the problem of powering LEDs from such a low voltage.
Fuji
Joined Nov 8, 2014
100
Thanks for the input.
I actually bumped it up to 3v now. It's the recommended voltage for reliability.
I am extending the track line past the LED. The LED's are just indicators. Im connecting it to a DC jack where I need at least 3mA to 4mA of current going through it.
I basically have 2v, 5v, and 9v option with the 4060. I need all to output the same current of 3mA or 4mA to the DC jack.
Bernard
Joined Aug 7, 2008
5,784
@ 3 V VDD you can drive a low Z load ( 10 ohm ) with 4 mA; @ 5 V maybe 4 mA into 600 ohm. 9 V VDD would be my choice.
