HI.
In this project we use a egs002 module to generate a spwm which is then fed to the h-bridge mosfets irf3205 the problem is that the final out that is fed to the transformer is around 6volts ac when i use a 12v battery.
this happens because the output of the egs002 module is around 11-12 volts which is given the higher side gate is not fully opened due to the fact that the gate voltage must be higher than the drain to source voltage i have tried boot straping externally but it didnt help also the module itself consists of a driver ir2110 that has a bootstrap capacitor is there a way to increase the output to 12v so i can use a12v transformer
thanks in advance
![Schematic-of-1kw-pure-sine-wave-inverter-circuit_Electrothinks.png Schematic-of-1kw-pure-sine-wave-inverter-circuit_Electrothinks.png](https://forum.allaboutcircuits.com/data/attachments/311/311662-b798a9bfa52ca8fc948f50a4b89580c0.jpg)
thanks in advance
