A single transistor is biased so it conducts DC current without a signal. Its output voltage is half the supply voltage so that its output can swing positive and less positive with the signal.Although I have a strong understanding of how an individual transistor works I am having trouble grasping how they work as a circuit. One example is how do they turn DC into AC.
Its DC current with no signal is low but its AC output current is high enough to drive modern low impedance headphones.I am beginning to look at this circuit http://electronics-diy.com/4x4.php Just another simple low current headphone amp.
No.Capacitors are used to remove unwanted frequencies.
Yes.P1 is volume and simply acts as a voltage divider.
The two output transistors operate push-pull. The diodes accurately match the voltage of the base-emitter diodes of the transistors and also change the same with temperature changes. The diodes keep the current from one transistor to the other at a current that is high enough so the transistors do not produce crossover distortion as one transistor turns on and the other transistor turns off. But the current is not too high that would waste battery power and cause the transitors to get hot.R1, R2, D1 and D2 are used to supply a bias current so the transistors work at any voltage rather than only activating at above 0.7v, I assume the diodes are in place as a voltage drop but not sure.
No.R3 may be another voltage divider.
Almost every audio power amplifier and opamp uses this "complementary emitter-followers" circuit. Q2 pulls up positively and Q3 pulls down less positively.As for the placement of Q2 and Q3 I simply cant see the logic in their placement, I cant work out how energy flows through this circuit to give a boosted output.
