Making a 1-bit adder using a Mux
jwatts
Joined Mar 10, 2008
3
So I have a homework problem where I have to make a 1 bit adder using a 4:1 Mux. Anyone have any ideas on this?
22,115
Let's have a quick review.
A one-bit adder has 2 input bits and one result bit. The two input bits represent one of four possible conditions.
A 4:1 multiplexer has four inputs and one output and TWO select bits. The two select bits select one of four possible constants (either 0 or 1) which can be routed to the output.
Are you starting to get the idea?
