Make program in pascal for ARM7, is possible ?
bernt
Joined Oct 16, 2010
5
Hi... Have you heard that a pascal compiler can create programs for ARM7 ? This is for a hobby project with a LPC2148, and i won't learn C or others...
Thanks.
retched
Joined Dec 5, 2009
5,207
Yes. Take your pick.
Google ARM pascal
and choose which one you wish to use.
[ed]
Ok, I got a little more interested in this. I have a development board called the EasyPIC6 made by MikroElektronika
http://www.mikroe.com
They also make an EasyARM dev board.
Point: They make a C, BASIC, and PASCAL compiler for many microControllers, so I checked to see if they made PASCAL for ARM...
Well it doesn't appear so. ;)
BUT, http://www.freepascal.org/ has a free PASCAL compiler for just about everything out there.
So there ya go.
[/ed]
bernt
Joined Oct 16, 2010
5
Hi retched and thaks for your reply.
I know about all products of MikroElctronika, beacause i already use my EasyPIC5 with MikroPascal PRO for PIC.:)
MikroE have not a pascal compiler for ARM...
I know as well Freepascal... it's maybe a good solution ?.... maybe...
Thaks
Regards
someonesdad
Joined Jul 7, 2009
1,583
Another approach could be to find a Pascal to C translator (search for "pascal to c"). Then you could write in Pascal and use a C compiler.
bernt
Joined Oct 16, 2010
5
Hi! a P2C converter is a good tool to translate, for example, this code: if H = true then Z := Z + 1;... but for a big algorithm (> 1000 line), with many loops (while, repeat/until), pointer and specifics types... it's more and more difficult to do a correct translation...
retched
Joined Dec 5, 2009
5,207
Honestly, you are the only person to bring up pascal in the last year or so..
I would see if the product has a following, and a forum.
There is likely where you will get good info on it.
I honestly would not mess with pascal.. I havent since TurboPascal in the early 90's
Im not saying you shouldn't, I have spent a lot of time "forgetting" pascal to learn 'C' and embedded basic, so I have my plate full... Same reason, i guess, that you will not learn C..
I used to love Pascal, just made more sense than C to me. I remember learning it on Alice Pascal (now free). Doubt it'll ever be more than a niche language for microcontrollers.
bertus
Joined Apr 5, 2008
22,994
As it is a french product you will probably not find many people who have tested it.
You can download a trailversion I saw on the website.
I do not know if there are limitations with it.
