Any luck with this problem? I have the same symptoms on my Thump. Mod edit: Moved from this thread.
B Thread Starter bpg5003 Joined Aug 9, 2020 1 Aug 9, 2020 #1 Any luck with this problem? I have the same symptoms on my Thump. Mod edit: Moved from this thread.
JoeJester Joined Apr 26, 2005 4,390 Aug 15, 2020 #2 Do this .... - Read the operators manual section on trouble shooting. - Write out your observations from when you energized the equipment. Take copious notes so your next post will have more info. - If it's an intermittent problem, wiggle the cables to see if you can change the symptoms. - If you made any measurements, like voltages, write down the results. - Do you have the necessary test equipment to repair this?
