MisterBill2
- Joined Jan 23, 2018
- 28,154
What I can tell you is that acetylene is one gas that can explode with a bang just in a paper cup sitting on a flat surface, with nothing except the inertia of the air above as resistance. Adding any obstruction will make it rather dangerous. And as for that 800 rounds per minute rate, 13+ openings per second is a real stretch for most solenoid valves. Possibly solenoid fuel injection valves, but I am not sure that they would have enough flow at the pressures that they use. So a start would be to copy some of the injector driver circuits.Looking at the drawings I can see where something like this could work but question the feasibility. The above drawings show the chamber as open, I question that. I would expect to see some form of pressure relief valve or poppet valve. The idea being you fill the chamber with an explosive gas mixture be it oxygen and propane, oxygen acetylene or other mixture. Then ignite it which will cause a rapid, very rapid, increase in chamber pressure. Once the pressure achieves the relief pressure it escapes with a bang. All of this takes place in a small fraction of a second.
Just as an example a typical rifle shot, I use "typical" so as not to get into cartridge or chamber specifics, takes place in about 2 mSec (0.002 Second). That means from ignition (primer ignites powder charge) to when the bullet exits an average barrel including bullet travel down the barrel. So we can safely say pretty darn quick. Now to get things in perspective a typical M16 or M4 has a cyclic rate of fire of about 800 rounds per min or about 13.3 bangs per second. The mechanics (gas system) of the rifle seem to do just fine at that speed. The cartridge develops about 50,000 (a little less) PSI of chamber pressure. This using US methods and procedures to measure the chamber pressure. Incidentally as mentioned, that is a cyclic rate of fire not a sustained rate. Things get hot real quick so at some point things need a pause for the cause, in this case heat.
I really do not see where any new technology is developed here. You ignite an explosive gas mixture in a chamber and get an explosion. The work is in the design. While I can explain the operation I haven't a clue what the real world numbers actually are and it will take some calculations and experiments to refine the process. I can tell you it will be a far from inexpensive project at a glance and only suggest how I might go about it. The initial setup would need some serious test, measurement and diagnostic equipment.
Ron
What is certain is that such a device could also be used as an effective firearm, needing only a mechanical system to load in a projectile to make it work. Sort of like the Vulcan gattling gun, except with gas power.
