LTspiceXVII not like LTspiceIV
c5f8
Joined May 3, 2007
9
My old computer was Win XP. I switched to Win 8.1 and installed LTspiceXVII. Now, circuits created with LTspiceIV are only accessible as complete diagrams in LTspiceXVII. I'm not able to click, cut, or change any component of my old asc circuit files.
Bordodynov
Joined May 20, 2015
3,431
I have no your problems. I open the old file by means of LTspiceXVII, change;vary it and save. Necessary only not to do the commentary on national language. Pottom I simply can open the file by means of LTspiceIV and work with this file. I think You necessary to start the program with rights Administrator.
Alec_t
Joined Sep 17, 2013
15,156
Strange. I have no problem running old asc sims, created with LTsIV on WinXP, using either LTsIV or LTsXVII on Win10. Admin rights not needed. Don't recall having any problem running them on Win8.1 either, for the brief period before moving to Win10.
eetech00
Joined Jun 8, 2013
4,724
Hi
Try funning ltspice as administrator just to see if that allows you to open and edit the .asc files.
If this works, then you'll need to run ltspice as administrator, or, change ownership/permissions on the .asc files, or move the .asc files to a non-privileged area of the disk.
eT
c5f8
Joined May 3, 2007
9
Hi
eT
I see the new version is as archaic as the last. Since last time I used LTspice I forgot to use scissors and components. Thanks for the replies.
