LTSpice Question
RRRRSSSS
Joined Jun 16, 2023
128
Hello:
Not sure if this is the right place to ask a question about Spice but
here goes. What is the parameter name for AC Gain for a BJT model.
DC Gain = bf.
Thanks,
RS
Audioguru again
Joined Oct 21, 2019
6,826
Of course you know that negative feedback and a load impedance reduce the voltage gain of a BJT.
Also, I showed that a BJT with a high AC gain has a low amount of negative feedback then at fairly high output levels the distortion is extreme.
38,834
DC Gain = bf.
There is no paramFor AC gain of a BJT,
LTspice calculates the collector operating current in the circuit, and then uses the DC gain at the collector current for the AC gain (in effect linearizing the gain, making it independent of the signal amplitude).
Audioguru again
Joined Oct 21, 2019
6,826
I think you want to know voltage gain but the beta gain shown is current gain, not voltage gain.
Unless you change the specs of the transistor model, the transistor you use might have minimum or maximum specs which produce different results than the "typical" specs of the model.
RRRRSSSS
Joined Jun 16, 2023
128
I tried to run the sim but I can't get it to work.
I've done something wrong. When I try to run it the dialog box pops up.
Papabravo
Joined Feb 24, 2006
22,112
The BF parameter of Spice is not the actual current gain. The proper name is "Beta Factor", and the description from the help page is "Ideal maximum forward beta". The implication is that the actual value of beta in a given circuit configuration has multiple inputs and parameter BF is only one of many. For more information you can Google:
"Gummel-Poon BJT model" and the number 1 hit will be the following Wikipedia article:
Gummel–Poon model - Wikipedia
RRRRSSSS
Joined Jun 16, 2023
128
The BF parameter of Spice is not the actual current gain. The proper name is "Beta Factor", and the description from the help page is "Ideal maximum forward beta". The implication is that the actual value of beta has multiple inpuf and parameter BF is only one of many. For more information you can Google:
"Gummel-Poon BJT model" an the number 1 hit will be the following wikipedia article:
Thanks PB
ericgibbs
Joined Jan 29, 2010
21,577
Hi RRR,
Open standard.bjt and insert the attached text.
You will have to close LTS and restart to get the My2N2222A active.
E
