Hi, I have been trying to simulate a simple transimpedance amplifier using the current feedback opamp LM4562 but I am getting this errors when I run the simulation:
WARNING: Node U1:1:U11:VP1 is floating.
WARNING: Node U1:1:14 is floating.
WARNING: Node U1:1:U11:VP2 is floating.
WARNING: Node U1:1:U11:VP3 is floating.
WARNING: Node U1:1:U11:VP4 is floating.
WARNING: Node U1:1:U11:VZ1 is floating.
WARNING: Node U1:1:U11:VZ2 is floating.
WARNING: Node U1:1:U11:VZ3 is floating.
WARNING: Node U1:1:U11:VZ4 is floating.
WARNING: Node U1:1:9 is floating.
Direct Newton iteration failed to find .op point.
Singular matrix: Check nodes u1:1:u11:vz2 and u1:1:u11:vz1
Iteration No. 1
Fatal Error: Singular matrix: check nodes u1:1:u11:vz2 and u1:1:u11:vz1
Iteration No. 1
This circuit has floating nodes.
The circuit I am using is attached.
Any ideas of how could I solve this? I looked into the model file but I don't understand it too well.
Thank you
Iteration No. 1
Iteration No. 1
Thank you
