LTSpice, how to measure attenuation in dB?
hrs
Joined Jun 13, 2014
538
I want to compare the attenuation of two transmission gate schemes using a CD4066 per attached schematic. Is there a way to show the attenuation in dB in LTSpice?
As an aside, is a CD4007 an equally good candidate for audio or is a CD4066 prefered here? Since the CD4007 also has an inverter this might be nice.
38,813
Use AC analysis with an AC source AC voltage of 1, which will give attenuation versus frequency in dB.
I think the CD4066 has a lower on-resistance so would be preferred on that basis.
Note that the audio signal peak levels must stay between ground and the Vdd supply voltage.
You do know that's a digital signal inverter, not analog.
ronsimpson
Joined Oct 7, 2019
4,812
Your SPICE file for the CD4066 etc. might not be accurate for what you are doing.
1) Simple SPICE model for CD4066 is a simple switch on/off.
2) More accurate on resistance = 100 ohms, off resistance of 10meg ohms? (I don't remember actual numbers)
3) Actually the on resistance depends on supply voltage and signal voltage. see data sheet
4) There are small capacitors across the switch. Capacitors from the digital to analog parts of the switch. Capacitors from pins to ground and supply. At 100khz and above the capacitance is more important than the resistance.
The on resistance is not just one number but has a wide range. The open resistance (leakage) has a very wide range. The leakage is more complicated than resistance.
hrs
Joined Jun 13, 2014
538
Thanks, this works! This gives more reasonable numbers than what I calculated from 20*log(Vout/vin). With 89 dB vs 104 dB @ 10V I somehow expected a bigger difference.
The scheme with one pass gate and one shunt gate requires two control signals opposite of each other. The inverter could be used to generate one or the other from a single incoming control signal.
The model I'm using comes from Bordodynov's collection. I'll have a look at the definition but I doubt it'll make much sense to me. That said, the attenuation with this model changes with different values for VDD, so I don't think it's just a switch.
Trying to plot for different supply voltages doesn't work with the following directives:
Code:
.step param V1 5 15 1
.meas Att1 param V(out1)/V(signal)
.meas Att2 param V(out2)/V(signal)
I think the sweep parameter needs to be between {} but LTSpice doesn't let me do that with either VDD or V1. Any ideas?
DarthVolta
Joined Jan 27, 2015
521
OP what circuit are you working on ? I'm working on my stereo and it has analog switches too. And in LTspice I've been just drawing sw's. I guess it doesn't matter for what I'm doing. But I did at 1 point have some IC on the schematic, but never ran a sim with it, just used it symbolically. I have to try some
hrs
Joined Jun 13, 2014
538
A long time ago ian fields said that
If you need good isolation, its common to use a pair of transmission gates. The control is fed directly to one and through an inverter to the other - one gate passes the signal, the second gate is shunt connected and switched on to short the signal when the series pass gate is off.
Recent events have afforded me the time to follow up on some things. I am now trying to quantify the improvement of a shunt gate over a load resistor. Either version may make it into any number of projects once I know what I want.
