LT3757 step up 48V to 88V fails
Teddy Doloir
Joined Feb 9, 2019
15
Hi all,
I try to use the LT3757 to step up 48V to 88V in order to driver a 88V led string. I made a simulation in LTspice and it works fine. So i decided to make a prototype based on the circuit's datasheet and formulas as following:
Design:
Vcc (chip supply): 12V
Vin(at the inductor): 48V / 8A
fswitch: 200kHz
Cout: 100µF
L: 600µH
Rsense: 0.04Ohms
Desired results:
Iout: 1000mA
Vout: 88V
When i switch on the circuit, without led string,i can see high output voltage that i can change with the feedback resistor divider. So i adjust the output voltage @ 88V. But, when i connect the led string, the output voltage drops down at 76V with only 10mA in the led string. Adjusting the Vfbx voltage has no effect on the output voltage which stays at 76V and Vfbx stays under 1.6V.
Could you help and explain me why i get this issue ?
Teddy Doloir
Joined Feb 9, 2019
15
No..., the 2x48V are adjustable (42V to 52V each), and i can drive the led string at 88V / 1000mA. I have already checked it. Now i want to use just one 48V power supply. That's why i need to step up this voltage with the LT3757. I don't think the problem comes from the leds. Something is going wrong with my design or components. I have checked all formulas and calculations and i cannot solve the problem.
Alec_t
Joined Sep 17, 2013
15,156
If you have 23 LEDs in the string, as shown in your schematic, the total forward voltage at 1A should be about 2.89V x 23 = 66.5V, according to the datasheet. Why are you aiming for 88V?
Teddy Doloir
Joined Feb 9, 2019
15
For the simulation I have chosen 23 LEDs because Vf ~ 3.81V @ 1A for each. I measured it with Ltspice.
As you can see on the slope, Vout ~ 88V @ 970mA in led string.
dendad
Joined Feb 20, 2016
4,641
A basic problem is that LEDs are current devices, not voltage. You need to make a constant current supply, not a constant voltage supply.
So, decide on the current you need and make a supply the controls that current. And has a sufficient voltage capability to overcome the forward voltage drop of the string of LEDS.
It may be worth trying to remove R3, change R4 to (1.6V/LEDCurrent) and adding it in the ground end of the LEDs so the regulator tries to keep 1.6V across that resistor, driven by the LED current.
I have not tried this but it may work.
Teddy Doloir
Joined Feb 9, 2019
15
The problem comes from the L value (600µH) to large. Calculations give 270µH so i change the induction with a 220µH avaible in my stock. The voltage drops until 83V with 320mA in led string. I suppose that my design cannot provide 88V because of inductor saturation (coil heating).
I think a 270µH 5A DC could match...
Do you think this one could make the job: https://static6.arrow.com/aropdfcon...08dc2dbc66f6c4eca00d469dde1/pm2120_series.pdf
Yes Dendad, you are right, i have already think about this way to drive the current. This first step up test was just for the power voltage stage capability.
