Hi all,
We converted our vehicle to LPG. As part of the installation, they installed a lubrication system (shown in the attached photo).
It works by opening the solenoid valve for few seconds depending on the RPM. Now we are noticing that the solenoid is not being triggered by the module.
Checks done so far:
1) Checked for suction from the black pipe - OK
2) Powered the solenoid manually - works OK
3) Checked all wiring continuity - all OK
4) Module was replaced by the supplier, but to no avail
Something which we noticed is that the signal coming from the spark-plug (used to monitor the RPM) is pulsing at 5V (see attached photo for wiring). Should this be at 12V to trigger the module?
Any suggestions of what may be wrong?
Checks done so far:
