Low threshold mosfet
Arjune
Joined Jan 6, 2018
354
I need an example part # of a couple of low threshold voltage n-channel mosfets in enhancement mode. A threshold voltage of 50 millivolts or less would be nice. I want to build an audio compressor with a power supply of 10 to 20 volts. I would prefer to-92 case. I don't want surface mount. Please consider low cost and where I could buy it from. I need at least six.
dl324
Joined Mar 30, 2015
18,341
You're not going to find any discrete devices with that low of a threshold voltage.
It would be helpful if you gave us more information on your project.
Low threshold devices aren't readily available in TO-92; at least not at a reasonable price. I've been using AO3400 0.65-1.45V in SOT-23. I use these adapters:
The MOSFETs are a $0.02 each and the adapters are $0.04 each on Ali Express. I wouldn't normally buy bare semiconductors from them, but I took a chance and haven't had any issues yet.
EDIT: The leads in the bottom of the picture are around $0.10 each in quantity 100+, if you can find them. Price is better if you buy reels of 25-40k pieces. You can use right angle male header pins instead.
Arjune
Joined Jan 6, 2018
354
I attach my test schematic. I am thinking that R5 would set the threshold and R3 would turn the transistor on or off at the threshold. This would allow the signal to pass or not to the output. The input to Output is never attenuated. the threshold of the transistor is 0.8v to 3 volts I think.
Audioguru again
Joined Oct 21, 2019
6,826
All the many audio compressor circuits in Google Images show an ordinary transistor or Jfet doing the compression.
Of course a compressor attenuates the signal when it gets too loud.
Here is a Wien Bridge sinewave oscillator that uses a Jfet for compression:
Arjune
Joined Jan 6, 2018
354
My compressor doesn't test correctly. The input signal is not limited by the circuit. I was wondering if I have to send back the audio output to the input of the mosfet gate rectified? How is the compression level point determined with respect to threshold level at the source of the mosfet? Stupid me.
Audioguru again
Joined Oct 21, 2019
6,826
A compressor circuit senses the input signal voltage and rectifies it. Yours does not.
Then the compressor circuit uses that rectified signal voltage to adjust the Vgs of the Mosfet. Yours does not.
Your circuit is a simple trimmer adjusted variable attenuator.
Arjune
Joined Jan 6, 2018
354
Got it. What gate voltage do I set R3 for to affect the 100 milli volt input signal
Audioguru again
Joined Oct 21, 2019
6,826
The amount of conduction for a Mosfet is a range of voltages. Each one is different even if they all have the same part number.
For a 2N7000 fed the 100mV signal from the 220k resistor the Vgs will be so low that leakage current will affect it. Use a Jfet instead and maybe reduce the 220k to 47k. You will need an opamp amplifier to make the active rectifier circuit.
BobTPH
Joined Jun 5, 2013
11,543
Are you trying to build a guitar effect box? If no, why are the signal levels so low? Line livel audio is around 1V.
Bob
Plamen
Joined Mar 29, 2015
111
Petkan: There are no known devices with so low threshold, but why would you need one? Schematic design should work with components limitations and part to part variations. You may find some devices fitting your expectations...but you cannot rely on re-produce able performance. When you use a device beyond what the datasheet guarantees - you cannot manufacture in volume and you cannot repair. Think how to use widely available components
Audioguru again
Joined Oct 21, 2019
6,826
I have never seen a Mosfet used for Automatic Gain Control (compression) but instead a Jfet was always used. It produces severe distortion if the signal at its drain is more than only 100mV but produces much less distortion if a voltage divider made with 2 resistors feeds half the drain signal to its gate.
Bordodynov
Joined May 20, 2015
3,431
I used an MOS transistor in the attenuator to stabilize the sine amplitude in the resonant voltage converter. I needed a low-noise source 12V--> 45V. So I made a transducer based on serial resonance (330 kHz). But I agree that the MOS transistor is not a very suitable element for an attenuator.
