Low-power MCU to 12 VDC Latching Relay Switch
Alec_t
Joined Sep 17, 2013
15,156
I'm puzzled by the drive arrangement for the relay. You have pins 15 and 16 of U1 shorted together? Doesn't the coil current polarity need to be switched?
38,777
Are you sure that 1kΩ in series with the relay coil provides sufficient current to reliably latch the coil under all conditions?
That only puts about 4.6V across the coil.
rbraddy
Joined Jan 26, 2017
17
Correct. The schematic is incorrect. I'm using 100 ohms and didn't update the default values. Another good catch.
