Hello group,
The current application I am working on is an alarm clock to replace the mechanical thing sitting on my bed. I plan to use an Atmel AVR uC to control seven-segment displays for the clock display, as well as using the internal timer/counters for the actual timekeeping.
My question here is, I want to make it portable and run off batteries, but I don't want to throw a linear regulator in there that will always be draining the batteries in the form of heat.
The largest drain will be the display, the AVR runs on tens of microamps when sleeping, so I want power regulation that will also be efficient. I am driving the LED segments with 7N2000 MOSFETS.
Any ideas here? Is an LM317 actually the most efficient method here?
