I am making a stomp board and need to make a passive band.Need to block all but 33hz to 100hz any ideas
I have an original Vox Crybaby, with the variable Q, that does it all. I don't see any reason to reinvent the wheel.I am making a stomp board and need to make a passive band.Need to block all but 33hz to 100hz any ideas![]()
You can combine a low pass with a cutoff frequency of 100Hz and a high pass with a cutoff frequency of 33Hz.I am making a stomp board and need to make a passive band.Need to block all but 33hz to 100hz any ideas![]()
At audio frequencies, it's okay to overlap windings, but it becomes a bit more complicated to calculate the inductance. Also, your chances of having some parasitic resonances increases. To be on the safe side, us a smaller gauge wire that you CAN fit on in one layer.Once i have the core covered and i still do not have all the windings on do i keep going back over the first windings????
Help please this is all new to me but fun![]()
Yes. It was a given that you'd have to go another round. Still, try to distribute the turns as evenly as possible once you're done.Once i have the core covered and i still do not have all the windings on do i keep going back over the first windings????
The filter you posted is terminated in 50Ω on each end, and will attenuate signals in the passband by 6dB. Am I missing something?Mik3,
Those are RC filters. While much easier to build than LC filters, our OP will require an active amplifier to boost the signal back up to where it's supposed to be. A properly tuned LC filter won't lose much of the passband signal at all; a mere fraction of a dB.
I made the assumption that the impedance of the circuit was 50 Ohms, which is typical for RF stuff. Without the termination resistors, the filter would be seen as somewhere between an open circuit or a dead short, according to the length of the transmission line. The resistors assure a good match.The filter you posted is terminated in 50Ω on each end, and will attenuate signals in the passband by 6dB. Am I missing something?
I was disputing your claim that it has negligible loss. With both ends terminated in 50 ohms, it has 6dB loss in the passband.I made the assumption that the impedance of the circuit was 50 Ohms, which is typical for RF stuff. Without the termination resistors, the filter would be seen as somewhere between an open circuit or a dead short, according to the length of the transmission line. The resistors assure a good match.
If his input or output impedance is not 50 Ohms, he needs to say something.
Why don't you upload your simulation of it, so that I don't have to re-create it in LTSpice?I was disputing your claim that it has negligible loss. With both ends terminated in 50 ohms, it has 6dB loss in the passband.
With a 50 ohm source and a high-Z termination, or a low-Z source and a 50 ohm termination, it still looks fairly good, and the attenuation is negligible. With a low-Z source and a high-Z termination (typical in audio, but not essential), it looks terrible.
You have to correlate the plots with the schematic.Why don't you upload your simulation of it, so that I don't have to re-create it in LTSpice?
Alternatively, you could download the freeware version of Elsie from this page:
http://tonnesoftware.com/elsie.html
