I am a lighting designer and like to incorporate fun, satisfying, and elegant interactions into my designs for how the light is switched on and off. I like to use regular LED light bulbs which require 120v wall power, and typical light switches (push buttons, rotary switches, toggle switches) all have a clunky nature to them. In short, they require too much force to operate for my liking. My question is: do any of you hardware experts know of low force ways to switch wall power on and off that ideally comes in a single component? I know I could do the relay route and use low a low force switch with that, but then I need a microcontroller and a power supply.
Some ways that I have addressed this problem in the past are:
- using a long lever microswitch rated for wall power, and attaching a pen click cam mechanism to the lever, to essentially create a latching microswitch
- using a on/off touch switch (one that you would see in touch lamps) attaching the touch wire to one leg of a mechanical keyboard switch, and the other leg of the keyboard switch to the ground wire for the lamp (running through a resistor/capacitor filter) to effectively trick the touch switch into thinking it is "touched" every time the keyboard switch is pressed.
Neither of these options are ideal, so I would really appreciate any advice! I'm also wondering how feasible it would be for me to create my own component that does this function for me. Thanks in advance!
