low current relay circuit question
darylrobert
Joined Sep 30, 2020
9
I have a 5v dc output connected to an indicator LED that is active when i need it de-activated. visa-versa it turns off (deactivated) when i want the LED to light. I need the current draw to be as low as a LED draw, i think a relay with draw too much current?.. i was looking at this relay, the control would be input but what is pin 3 N/C (normally closed) ....thankyou
Martin_R
Joined Aug 28, 2019
137
Easiest solution is to use a small signal PNP transistor as shown in the attached circuit. It's function is to invert the input signal.
PhilTilson
Joined Nov 29, 2009
155
You don't specify what this 5V output is - is it a microcontroller output pin, for example? If so, then why not simply connect the LED to the other rail? For instance, if the LED is presently connected + to 5V rail and - to output pin, connect instead + to output pin and - to ground. This will 'reverse' the operation as you require.
35,091
We don't know how the LED is being driven or what is driving it. But as @PhilTilson said, you may be able to drive the LED through one resistor, depending on whether the LED needs to be on the high side or the low side.
28,125
Mr Chips offers the simple solution in post #4, but that solution is at best a guess because we have not a hint as to if the output is sinking or sourcing current, nor how much current it can provide in the other mode. The suggestion about simply reversing the LED is inherently wrong, also.
So now the question goes to the TS to describe the driving circuit details as asked.
darylrobert
Joined Sep 30, 2020
9
thankyou all, i have sourced a ready made 5v relay module thats trigger current is 5ma. I have tested it and its more complicated than i wanted but it works.
28,125
Use one of the circuits posted by Mr. C in post #6. Presently your circuit probably looks a lot like one of them, so use the opposite one to reverse the logic. Fairly simple and really cheap.
28,125
If your low=on output can sink 20 mA then the upper circuit shown in post #6 will work quite well. If not, your circuit with R2=470 ohms and R1 =2.7K ohms should work.
28,125
NO, I don't think so. My answer, as the others, have been in response to a question about an output able to light an LED, requesting that the solution use no more current than that.
If the output is an open collector, or an open source, that is an unstated possibility, and in that case the answers need to be a bit different.
BobTPH
Joined Jun 5, 2013
11,631
If you want help, you need to answer our questions. Solutions have been proposed that May or may not work depending on what is driving the LED.
So, once again, what is driving the LED? If you don’t understand the question, please ask for clarification.
Bob
