MaxHeadRoom
- Joined Jul 18, 2013
- 30,661
Code requirement not needed for 9vdc!wouldn't the system monitoring the rod need a ground to work?
OH! No, No please don't say earth ground will work ....This is not code.
Brzrkr
Max.
Brzrkr
Someone else brought up about a power panel, not me. This does not relate to a power panel.If this poor man is staying awake at nite worrying about his power panel losing ground.....then there is a solution.
This does not relate to a indoor appliance. Not sure why that would be mentioned.If this man is worried about losing ground on an indoor appliance, then there is another solution.
Correct. This is more about wire continuity, or as I realized today, reverse continuity.The man may not need to check the ground.
yesHave you ever lost one of those grounds?
Several timesHow often?
YesCan you build circuits and do you have spare conductors thru out site for power and alarm connections?
Without a diagram of what this circuit is supposed to look like I'm not sure how this would work.If the relay opens it triggers the NC contact and supplys the alarm.
Thee complaint is that the grounds somehow fail, the request was for a system to detect and alarm the failures. While it might be that some preventive measure could be made to work, that was not the request. A checking system similar to those used with building fire alarm systems is what I suggested, using an approach that has been demonstrated to work well and be reliable as well as self-supervising. And fairly inexpensive. It could also possibly be made to work with battery power, but I have not considered the scaling of voltages and currents that would require.Wire to ground rod connections are done differently than standard connections.
e.g. CADWELD https://www.borderstates.com/Catalog/1K/1K20/164961
Not really sure. Could be anything as they are in the yard. Doesn't have to be a clean cut, could have been corrosion over time. One looked like it was chewed. I'm not really looking for a way to stop that from happening. Just need to know when it happens.What was the cause of these multiple ground failures?
Thank you for understanding.Thee complaint is that the grounds somehow fail, the request was for a system to detect and alarm the failures. While it might be that some preventive measure could be made to work, that was not the request.
There will never-ever be any kind of current on that ground conductor, unless the current somehow comes from out of the rod staked in the dirt.Any current thru that ground conductor.....will lift that ground.
I was thinking about this too, or maybe even an op-amp or LED and when the ground breaks the LED goes off, setting the buzzer to trip.I was thinking of inducing an impulse, intermittently, to check.
For sensing continuity there must be some current through the connection being monitored. Without a very sensitive method of monitoring the current, the current must be enough totrigger the alarm function.Not really sure. Could be anything as they are in the yard. Doesn't have to be a clean cut, could have been corrosion over time. One looked like it was chewed. I'm not really looking for a way to stop that from happening. Just need to know when it happens.
Someone from work today told me that I could do what I needed with an Arduino (using DC). I'll try to get more details on this.
Are you saying that if I use a 9 volt battery on the relay coil then the (minimal) amount of current would be coming from the battery? If so then this is acceptable.For sensing continuity there must be some current through the connection being monitored. Without a very sensitive method of monitoring the current, the current must be enough totrigger the alarm function.
