Loopsticks, AM radio, which topology might be best?
Hamlet
Joined Jun 10, 2015
560
Anyone have any experience with loopsticks? I have a surplus available,
and thought I might try something different. I haven't seen a radio
with more than one loopstick, except perhaps for a nulling loopstick added to
sharpen tuning.
28,488
Mostly, a single rod is used because it is cheapest and adequate for most. Also, with a reasonable number of turns the inductance will be correct to resonate at the desired frequency. So that is how the loop-stick for a common consumer broadcast radio is selected. Other applications may require alternate arrangements. The size and amount of core will affect the inductance per turn, and that will often affect the performance of the radio.
ronsimpson
Joined Oct 7, 2019
4,851
AM radios sound awful. Most high audio frequencies are missing like on an old phone.
At one time that sounded wonderful. Music over the air. Wow.
From an audio engineer, now dead 40 years. "We did not know there was audio information at high frequencies." Our microphones said there was very little high frequency information, and the speakers could not make high frequencies. "When we made better microphones, we were surprised."
28,488
Given the ten KHz channel spacing and the resultant 5 Kc max signal frequency, it is not so very awful for a lot of the stuff. Certainly actual AM broadcast audio is, and was, a bit better than that. So one person's music is another person's noise. And on FM, Andre Castilanitz and his 101 strings sound just as awful on the best system in the store as they do played on a PA system through a 5 inch paging trumpet.
So while the technical numbers are much better, the "awful" aspect is in the ears of the listener.
28,488
Note for youngsters: kc = kHz
Sorry about the slip. Kilocycles remained long after electronics stopped using condensers. And I never could figure out why condensers were used in electronics, when they were providing capacitance. But that would be a completely different discussion.
DickCappels
Joined Aug 21, 2008
10,661
No problem, it took me a very long time to stop thinking kc and to start thinking kHz. Kind of like going from Gauss to Teslas but less stressful.
Hamlet
Joined Jun 10, 2015
560
I was thinking a larger ferrite rod loopstick might increase signal, because the rod acts as the antenna.
In a web search, folks that repair radios report that gluing broken loopsticks back together results in little degradation of signal. I suppose this means I can bundle rods together to create any size I want. (however, this doesn't work very well for SMPS, as I discovered, you loose half of your inductance fidding with a broken toroid.)
28,488
Certainly a larger loop-stick should collect more signal, but if the application uses a TUNED RESONANT loop-stick then if the inductance has changed there may be a loss. But I have not experimented to see how much loss.
DickCappels
Joined Aug 21, 2008
10,661
A ferrite rod antenna is a lot like a loop antenna with a core. Yes, you can glue rods together to improve sensitivity.
I think it is now gone from the web but I remember an web page about Lowfer Radio from about 15 years ago in which the author had stacked and bound together several long strips of magnetic material to a huge rod antenna, maybe 3 meters long, upon which he wound a coil and added a resonating capacitor and preamp to pick up distant Lowfer radio signal.
28,488
I did read some articles about some sorts of resonant LowFer receivers and antenna sections. The challenge always being the conflict between wire size and coil "Q", with the coils needing higher Q also needing many turns to be resonant. And the many turns wanting thinner wire to reduce size and weight.
Hamlet
Joined Jun 10, 2015
560
I swapped in one of my new 300mm ferrites loops, and I've got 3x the DX that the previous 75mm ferrite loopstick was showing. I don't know if the effect is linear (problably not) but I'll try gluing two of them together and see what I get. Thanks everyone for the input.
