Looking for inexpensive 12v PID for project
38,753
Are you trying to control the temperature of the water?
Why do you think you need PID?
That would be overkill for such a task. ;)
gwfami
Joined Jan 18, 2018
50
I'm not going to use it for water, I need to sublimate a chemical at about 230 C, but it decomposes at 250 C, hence the need for precision control.
To quote a great man regarding overkill...
"When you need it, and don't have it, you sing a different tune."
gwfami
Joined Jan 18, 2018
50
ebeowulf17
Joined Aug 12, 2014
3,307
Thanks, have already looked at that, but the amperage is below what I need, and I don't want to complicate things by adding a second relay.
Dual output SSR(5~8V, 40mA), Relay(3A 120V AC)
Ahh, I've never seen or used a PID controller without using a separate relay for the power switching, so I wasn't thinking in those terms at all.
I suspect it'll be easier to pair a readily available PID controller with a readily available relay or SSR than it will be to find the high power PID you seek, but I could be wrong. Best of luck whichever way you go.
