Looking for expertise on electronics
Jack squire
Joined Mar 29, 2023
6
Hey guys, I’m looking to build a tow behind spray trailer , to pull behind my vechile to spray grasses, am going to have a 12v electric pump, that I want to have automatically turning off when not moving, I have thought about running a wheel speed sensor of a car, but not sure how to covert the ac sensor of a wheel speed sensor to activate a relay, if you have any ideas on how I could do so, have a easier way to do so please reply, Jack squire
LowQCab
Joined Nov 6, 2012
5,101
If You need something factory assembled ..........
https://www.summitracing.com/parts/lpe-l460340004
This box will count the Heads of your Wheel-Studs with
a common Anti-Lock-Brake-Wheel-Sensor,
and turn-on a Relay a the speed that You set.
I can also turn it back off if the speed gets too high.
( You have o fabricate the Mounting-Bracket for the Sensor ).
Jack squire
Joined Mar 29, 2023
6
T
Thank you
