Looking for DTMF gadgets...
Externet
Joined Nov 29, 2005
2,668
So how close does this device come to what you need?
Thanks. Nope. That item is an encoder and probably not DTMF. For vandals protection, there is nothing outside the door at the protected site to avoid destruction, not a keypad nor even a door knob. The door can be opened only from a solenoid activated by the radio receiver inside. Has to be decoding a DTMF sequence of 4 digits. The TX encoder solved by using a talkie with keypad (or a mic with it) instead of/at adding a toner (first image) at a base station transmitter.
Same here. However, while inexpensive these Chinese modules aren't exactly bursting with data sheets. This is an example of what I played around with.
Fortunately the I/O pins are clearly marked up. The jack is just another signal in.
Then I suggest you Google "Cipher Locks Circuits". While I see no need for DTMF you can use it if you like.
While you oppose using a uC using a single simple uC with a module like I posted above would make this project much easier. However that is your call.
Ron
https://www.mouser.com/datasheet/2/268/mt8870d_datasheet_oct2006-1954007.pdf
Wendy
Joined Mar 24, 2008
23,809
Making one is not hard, I suspect that you're going to have to make what you want they may not make them anymore and they may not be selling them anymore.
