Looking for custom made power supply PCB
engr_david_ee
Joined Mar 10, 2023
364
The input to the OpAmp is 0 to 3.3 V. I am using OpAmp in unity gain inverting configuration. The output of the OpAmp will be 0 to -3.3 V. The problem is that the output current of the OpAmp I have selected can not deliver 500 mA if a load is connected. I know that there are OpAmp with higher output current but for some reason, I need to find a solution with AD8397 OpAmp. One option is to buffer the output using a transistor to increase the output current. I am using PNP at the output of OpAmp. The schematic is attached. Kindly have a look and suggest how can I get 0 to -3.3 V at the load that require 500 mA. Note that the input of the OpAmp will be controlled by DAC/FPGA to get adjustable power supply at the load.
engr_david_ee
Joined Mar 10, 2023
364
To simplify I just simulate inverting OpAmp output. The input is 0 to 3.3 V and the output is 0 to -3.3 V.
The load requirement is 500 mA with a variable voltage 0 to 3.3 V. The OpAmp AD8397 we selected can not deliver that much current. Can a push-pull stage using PNP and NPN solve the problem ?
engr_david_ee
Joined Mar 10, 2023
364
I also simulated push-pull stage separately. The transistors PNP and NPN can work at 500 mA. I am wondering how can I combine this push-pull with the OpAmp. So that I get variable voltage between 0 to -3.3 V on the load.
