Looking for computing component
Carter_5082
Joined Nov 29, 2018
I am looking for a component that will take in a signal from another component, then tell another machine (motor) what to do. (It will tell the motor when to run, how long to run, and when to stop)
27,513
There are a lot of vendors that will gladly sell you a drive that will do just exactly what you asked for. BUT given that you provided a really broad description and not much detail, it is probably not what you really want. But lots of drives are available for purchase. Providing an adequate description of what you seek is rather vital to the task of finding it.
27,513
How about a CNC Milling machine? :p
Max.
Max, that only satisfies the very broadest part of the description, not the "motor" part of it.
I have used a programmed driver for a linear induction motor that did do exactly what was requested. The distance and rate were programmable and very repeatable. I will not wander off here and tell a story that is only distantly related to the topic.
But the short summary is that programmable motion controls are available from many sources and for almost any size of motor. But none of them are cheap.
