Hi:
I am looking for NMOS PH2625L transistor thru hole or something incan solder manually. I only need about 6 of them but cannot find it. I need cheap one or cheap transistor that has similar characteristics vto = 1vdc and thru hole or something I can solder manually.
Also I need cheap 400ohm, 10k ohm resistor, 1000 ohm, 100 ohm and 5 ohm resistor thru hole that do not get hot or dissipate heat.
Please post any links for purchase.
Thanks for all help
Thanks for all help
