Looking for a PCB power jack
18,106
I need something like this.
I'm having trouble finding one that will definitely fit a protoboard with 0.1" hole spacing, like these. It seems most jacks have leads that are too fat to fit in the holes, and/or don't have the pins on 0.1" centers.
ISB123
Joined May 21, 2014
1,236
You could try sanding them down or glue them with hot glue,bend the legs back and solder wire on them and pull the wire through the holes.
18,106
Haha, love it. Don't know why I didn't think of that.
I guess I was hoping someone here knows of the perfect part.
30,665
Co-incidentally I fitted one today on strip board, it is smaller than I usually use however, I generally drill the board to take the 6mm recepticle size, the .1" spacing version takes a 4mm dia power plug end. The holes have to be slightly enlarged to enter the strip board.
I got these from Digikey.
18,106
This project is not going in a box, and that's why I was looking for PCB mounting, but now I'm leaning towards putting a little patch panel next to the mounted PCB. It may give me more, simpler options.
#12
I use the drill method because that's what is convenient in my tools. I can put any size hole anywhere and compensate on the copper side, but this idea might work even better!
18,106
The protoboard has no copper side, so widening the plated through hole risks removing the plating entirely. That might be OK. If hole size was the only hurdle, I might drill. The 0.1" pitch is another problem. I can bend, glue and wire if I have to. Still weighing options.
