Looking for a general pupose 2-way wireless keyfob
strantor
Joined Oct 3, 2010
6,875
I want something like some aftermarket car alarms have, where there is a Keychain fob with a few buttons and a little display. The display will tell you if your alarm is going off or if your door is open, etc.
Instead of connecting to a car alarm I will connect it to an arduino or similar. I do not need a fancy LCD, just a couple of LEDs would work (and a piezo beeper would be nice).
I have found many cheap key fob-to-relay-output kits on amazon, but none that sends signals back to the keyfob, like the aftermarket alarm systems. I have also found some aftermarket alarm systems for under $100 that i might be able to repurpose for my needs, but the scant details make me reluctant to make a purchase.
Has anyone here seen something like this? Does it exist? Or must I make every useful thing myself?
cmartinez
Joined Jan 17, 2007
8,843
I've never seen anything of the sort. And now that you've mentioned it, I'm surprised it's not a common sight.
That seems to be the case!
On a side note. I have no idea what you want out of this thing, but have you considered using a bluetooth device and a smartphone to get the results you want? ... as opposed to having a dedicated gizmo for a single purpose.
strantor
Joined Oct 3, 2010
6,875
Bluetooth range is pretty limited for my purposes. My purposes are... an alarm, remote start, power door locks & etc for my truck. It's a '93 chevy truck so not much CANbus stuff going on, which is how I think most of these aftermarket systems are designed to interface with a vehicle. And i want to do some unorthodox stuff with it too. I have a camper on the truck in which I want to keep a bunch of expensive tools. I want to put electric door locks on the camper and switches to register the doors open/closed. I am often several hundred feet from where my truck is, and I want to know if someone gets in there.
Perhaps there is an aftermarket alarm which has plenty of customization available and would meet all my needs. I started to investigate but it feels like the entrance to a rabbit hole that I wouldn't need to go down if this super useful thing would just exist as it's supposed to. I could roll my own system faster than figuring out how to implement someone else's, and I've already got everything else I would need. I can't justify putting a $1500 alarm system on a $500 truck.
