Looking for 4pin connector with 2 pins 80A + 2 signal pins
BrMisha
Joined Aug 13, 2022
32
Hello!
I have an aluminum box with batteries+bms inside and i need to add connector with 2 power pin and 2 pins for canbus.
The max continue DC current on power pins is 50A.
There is cooling fluid inside box so connection between connector and box must be fully sealed.
What is connector better to use?
In worst case i would use 2 connectors for power pin and canbus.
Thanks))
ericgibbs
Joined Jan 29, 2010
21,428
Hi Br,
OK, I guess you will ensure that the cooling liquid will not attack and degrade the connector and the sealing, especially around the connector pins.
Good luck with the project.
E
