looking for 2pin cover
pager48
Joined Nov 25, 2018
161
Are there any 2 pin 2.54 pitch plastic covers which slide over without any electrical contact only to prevent them from being shorted when not in use?
SamR
Joined Mar 19, 2019
5,487
What you use are 2 jumpers, one on each pin with the other half not connected. IE turned 90 degrees from normal use. Or a 2 single or 1 double pin dupont female wire terminal without the wire...
I know the connector that @SamR is talking about. If you just need a few, you can use something like https://www.digikey.com/product-detail/en/te-connectivity-amp-connectors/925366-2/A106488-ND/2054446, but you need the pins too. Just insert the pins without wires and crimp them around nothing. I think you can cut the top to the desired length.
I remember these: https://en.wikipedia.org/wiki/Berg_connector
2.5 isn't 2.54, but this https://www.digikey.com/products/en?keywords=A105181-ND should work. Again, you need to buy pins.
