Looking for 2.54 mm or 2.5 mm Connectors – Board-to-Board & Board-to-Wire
dotcomdotcom
Joined May 5, 2023
10
Hi all,
I'm having some trouble finding suitable connectors and hoping someone here can point me in the right direction. I'm looking for a 2.54 mm or 2.50 mm pitch connector (preferably through-hole) that supports:
Board-to-board (one side 90 degrees, one side 180 degrees)
Board-to-wire (compatible with crimp housing or prebuilt harnesses)
Total of at least 16 signal pins, ideally in 2- or 4-pin units (but open to other configs)
These connectors will carry low-level analog signals like:
Voltage sense (≤ 5V)
PT100 RTD sensor wires
I am looking for something with good signal integrity, firm mating, and ideally something suitable for mass production (low cost, reliable availability, not NRND/EOL).
I’ve looked at:
  • Molex KK 254 (no 90 degree)
  • Phoenix Connectors (no 180 degree connector)
  • Wurth (Only Board to Wire)
Does anyone have part numbers or proven combos that work for this kind of use? Maybe I overlooked a previously mentioned manufacturer.
Thanks in advance — any help is appreciated!
Jon Chandler
Joined Jun 12, 2008
1,573
I really like this style from Tayda Electronics. Note that instead of being in the air, away from the board, the tab is flat against the board – this eliminates the problem of getting the connector square to the board.
Do note this changes the position of pin 1.
