hi friends
i have problem with logic works
i need Logarithm circuit with "logic works"
can someone help me????
plzzzzzzzz
plzzzzzzzz
i exactly dont know what kind ? analog or digital?First, what kind of logarithm circuit are you talking about? Analog, digital, ...?
This is not the Homework Done For You forum. You need to show YOUR best attempt to solve YOUR homework problem. We will then help guide you along the path to the solution if we can.
"seven segment" is not a representation format. A representation format is something like "unsigned binary", "twos-complement", "IEEE-754 single-precision floating point", "fixed point".yes.
in seven segment
For both cases?shows error
I don't understand what you are saying here. I suspect it is just a language barrier problem, so try rephrasing.
more intricacy accord
by Jerry Twomey
