Logarithm
33,107
First, what kind of logarithm circuit are you talking about? Analog, digital, ...?
This is not the Homework Done For You forum. You need to show YOUR best attempt to solve YOUR homework problem. We will then help guide you along the path to the solution if we can.
serial2222
Joined Dec 27, 2014
9
i exactly dont know what kind ? analog or digital? :(
but i not one kind electric circuit diagram can be design with logic work
like this : http://t0.gstatic.com/images?q=tbn:ANd9GcSHOVeCKma5-JakuSBwuYzJ0m3N7vFPyE-Qq4Lm494X1M5c0IMo
but i say i become dizzy :((
help me plzzzzzzz
33,107
Again, how are the values A and B represented? Unsigned integers? Two-complement? IEEE Floating point?
What, exactly, is the assignment?
33,107
Okay. So focus on taking the base-2 logarithm of a two's complement number.
What representation is the output supposed to be in?
33,107
Okay.
So what should the output of your circuit be if the input is 5? What should be displayed?
What if the input is -12?
33,107
:confused:
more intricacy accord
I don't understand what you are saying here. I suspect it is just a language barrier problem, so try rephrasing.
You said that if you have an input value of 5 that the output should show error. So in response to that I have two questions:
Why should the base-2 logarithm of 5 produce an error?
How will you show an error on your 7-segment displays?
In addition, I asked you to describe what input values (at least give an example or two) should not produce an error and what the output values should then be.
