The size of the object would be of an issue in the box as if it was say...1/3rd the volume of the box...well then...this would present problems! LOL!I have been watching the development of this thread with interest.
There is, of course, a vital missing piece of information.
The size of the 'object' in the glass box. It appears to have miraculously shrunk to a point in all analyses so far presented.
If the distance and directions are known to six known points in 3D space the information (for a point) is redundant and surveyors would employ some statistics to complete the task.
But for the sake of this question...and I know I should have been more specific and I will be so next time....treat the invisible object as if it were the size of a pea in a box or rectangle....between 1 and 2 meters per side.
As far as you last sentence I quoted above....If the distance and directions are known to six known points in 3D space the information (for a point) is redundant and surveyors would employ some statistics to complete the task.[/QUOTE]
Sure...that would work...IF you knew those exact distances and directions. But if you are at a point very distant and at a angle very different from those points from what you would be from Earth...and if you had issues with your crafts sensory equipment....and you needed to do this Geometry and plot a course to this hidden star system manually....you are going to use those 6 known and relative points to do so.
The whole object of this topic is to present the needed method of plotting a course to a invisible or hidden object or in the bigger picture...Star System.
Split Infinity
